PIONEER AVIC F500BT- NO MAP VERSION
By angelgps · Jul 09, 2012in Problems/Troubleshooting💬 11 posts👁️ 6,176 views
Posted Jul 09, 2012 · 22:17 UTC#1
Hello, I have an AVIC F500BT, and I downloaded the firmware update 4.0 on the pioneer site, since then, the version 4001000 2007000 replaced the original version, but the map disappeared, and when I check the settings, informs THE MAP VERSION (as map was not installed at all, please someone help me?
I have entered THE TEST MODE AND PASTE MY FLASH/LPUE080/APL2/ IGO / CONTENT / NO MAP IS NO FOLDER
THERE IS ONLY THE FOLDERS: LANG, SCHEME AND TMC.
THANK YOU!!!
Posted Jul 10, 2012 · 01:02 UTC#2
do you have a back up?
Posted Jul 10, 2012 · 15:25 UTC#3
hello I have no backup of the old version (2:007000), for the 4:001000 version of the SD card installed automatically replacing the previous one, the update has completed, the problem is that the map is gone. Please how can I do to install this map F500BT?
Edited Jul 10, 2012 by angelgps
Posted Jul 11, 2012 · 02:44 UTC#4
I'm not that familiar with the f500bt but if it's an official firmware you uploaded purchased via pioneer you should call and ask why this oils happen. They should be able send you a proper update.
Posted Jul 12, 2012 · 21:15 UTC#5
Hello, please does anyone know how to manually install IGO? since the firmware update 4.0 not installed map.
Edited Jul 12, 2012 by angelgps
Posted Jul 12, 2012 · 23:48 UTC#6
It's because 4.0 doesn't have maps in it. Did you buy an official copy if so from where?
Posted Jul 14, 2012 · 15:44 UTC#7
hi, since we do not have maps in version 4.0, how can I do to instal a map? and what map? please help me, I'm from Brazil, and pioneer of Brazil does not support this type of gps. Thank you!
Edited Jul 15, 2012 by angelgps
Posted Jul 17, 2012 · 17:45 UTC#8
i suspect you did something outside of downloading the update and allowing pioneer to update normally.
If you are using 4.x sw without having upgraded with CNSD-200FM properly, then you will need to obtain official maps somewhere, or most likely:
1. find igo8.3 compatible maps/pois and drop them in the content folder
2. find "patched" igo (aka ezrider.exe) along with "unrestricted" igo licenses..
search around the forum for posts by "carver"
Posted Jul 17, 2012 · 21:28 UTC#9
The issue is I think he will struggle with finding igo south america. His ezrider should already be patched and correct license files on it. But Ubless you have a backup of your avid before you modded it nothing can be done. Have to have brazil maps in hand.
Posted Jul 06, 2013 · 21:20 UTC#11
Firmware 4.0 is not compatible with f500bt. Even if you manually put maps files in it. It will not respond after you reboot unit.
If anyone successfully updated f500bt with 4.0 firmware then give us steps.
