Avic on a gm factory xm antenna
By gm2376 · Feb 03, 2007in General💬 7 posts👁️ 1,332 views
Posted Feb 03, 2007 · 20:51 UTC#1
Tried searching and couldnt find anything. I want ti get a z1 or d3 and run xm and gps through my factory xm antenna. I have a 07 trailblazer ss, and evryplace i asked said they can't do( which i figure is bs) and say i have to use a seperate antenna. I also have onstar which i need to keep in tact. Is this possible? Would i need the xm moduale, or would i just use the factorty one. It would be replaceing the bose 6 disk changer.
Posted Feb 03, 2007 · 21:55 UTC#2
Its not bs.
You will need to buy a new XM module, you can't use the one from the factory. The XM antenna might work for XM, but you still need to run a seperate antenna for the GPS.
You can keep the bose and onstar, I don't know the numbers off hand, but Peripheral makes adaptors so you can keep Onstar, Bose and the door chimes.
Posted Feb 03, 2007 · 22:13 UTC#3
I don't know the numbers off hand, but Peripheral makes adaptors so you can keep Onstar, Bose and the door chimes.[/quote
U have a link to where i can find those items?]
Posted Feb 03, 2007 · 23:00 UTC#4
Google Peripheral and look on their website.
Posted Feb 04, 2007 · 04:39 UTC#5
http://peripheralelectronics.com/prodDe ... strSearch=
That's what you'll need. Yes factory mx antenna can be reused. You need to run a new gps antenna. Other than that have fun.
Posted Feb 08, 2007 · 23:11 UTC#6
not usable? The module is functional. What is missing?
Posted Feb 08, 2007 · 23:23 UTC#7
The factory tuner will only work with the factory radio. There is no interface to allow the aftermarket radio to control the factory xm tuner.
