error in the agenda F700BT
By caiati · Jul 12, 2012in Problems/Troubleshooting💬 9 posts👁️ 1,283 views
Posted Jul 12, 2012 · 19:54 UTC#1
good night, I have long had a little problem, is this: I trnsferido all contacts to my avic F700BT but when receiving a call in which I have on the agenda of the phone, I see the name on the avic . may be strange but would need someone please give me solution to this. Thank you.
Posted Jul 12, 2012 · 20:30 UTC#2
do you have an iphone? need to edit phone book data
Posted Jul 12, 2012 · 22:09 UTC#3
I have a samsung Galaxy sII
Posted Jul 12, 2012 · 23:45 UTC#4
You need to modify how you have contacts phone numbers or you need to get the phone book out of aviv and modify it in excel or a program ment to modify phone book data
Posted Jul 13, 2012 · 00:34 UTC#5
First thanks for answering, but not how. from the choice of the F700BT I transfer contact list, but when I call being on the agenda of f700 I see the name ....
Posted Jul 13, 2012 · 01:14 UTC#6
The F series is very picky in the way the phone numbers are entered, and though your phone is smart enough to recognize the differences in incoming number patterns your avic is not. For example in the states the avic will not pop up with caller ID if you do not have the area code in front of the 7 digit number. It also struggles if you have an +#- in the number. Long story short it's picky and it's my biggest frustration with the unit.
If you search hacks/mods section for phonebook fixes you will learn a lot more. It's been about 2 years since I've modded mine in this way. The basics are is you need to get into test mode and copy the file where your phonebook is saved, copy it on to SD card. Then use a program to modify all your contact info so that it's in a format that avic will link to the appropriate name in your contacts.
Posted Jul 13, 2012 · 11:44 UTC#7
not how, TAIL24, could you detail me. Thank you.
Posted Jul 13, 2012 · 14:21 UTC#9
the program they offer's link is dead but you can use
SQLite Expert Personal edition
