Netflix Issues with Z130BT
By onesickGS · Jul 12, 2012in General💬 5 posts👁️ 1,498 views
Posted Jul 12, 2012 · 21:37 UTC#1
Currrently running the z130BT in my car, have done the bypass and everything. Everything works fine but Netflix on the HU.
I would disconnect my iPod, turn the settings to off, then proceed to turn on netflix on my iPhone, load the video, press play, and hook it up the the HU. What exactly am I doing wrong?
Can anyone help me out?
Neither my girlfriends 3GS, or my iPhone 4S worked.
iPhone 3gs Firmware = 5.1
iPhone 4S firmware = 5.0.1
Netflix is currently version 2.2
Posted Jul 13, 2012 · 14:51 UTC#2
Does playing an actual DVD work?
Edited Jul 13, 2012 by stargate125645
Posted Jul 13, 2012 · 20:29 UTC#3
Netflix video out is only supported on i4 so that explains why it doesn't work with the 3GS.
Posted Jul 13, 2012 · 21:35 UTC#4
Is that like Apple's force-you-to-upgrade shenanigans of Siri not working on 3GS, or is there a hardware limitation for that like processing power? If it's the latter, several Android phones should be having the same problems (on AppRadio 2) - my old one certainly would! But if it's supposed to work on the 4-series, I would have no idea what the problem is.
Have you tried playing videos from an SD card?
Posted Jul 14, 2012 · 00:43 UTC#5
If you are jailbroken on the 3GS with a tv out app it will work. Native tv out is only supported on i4 and above.
