Appradio replacement cable ?
By yonel · Jul 13, 2012in AppRadio, AppRadio 2, AppRadio 3💬 3 posts👁️ 2,139 views
Posted Jul 13, 2012 · 01:42 UTC#1
Just a question
if i refer to my last experience with avic F700 and iphone...
the video issue only worked with an original apple composite cable ( with the resistor inside connector...)
so, we have a kind of an Svideo ( A/V) input cable too in the appradio
can we imagine instead of buying original pioneer cable of the sph-da01 buying a composite cable with the usb and rca connector AND an svideo with female rca connector ?
http://www.google.fr...dK%252B6BNdyEI2)3Q~~_35.JPG&w=300&h=300&ei=Hmn_T9XyH8K7hAets9j3BA&zoom=1&iact=hc&vpx=507&vpy=149&dur=113&hovh=225&hovw=225&tx=90&ty=110&sig=114568816362713469170&page=3&tbnh=144&tbnw=152&start=44&ndsp=24&ved=1t:429,r:2,s:44,i:220
AND but in female RCA version
http://www.prlog.org...-male-cable.jpg
Edited Jul 13, 2012 by yonel
Posted Jul 13, 2012 · 01:47 UTC#2
the appradio doesn't use composite or s-video. it uses a Y Pb Pr video connection. the easiest way i found was to buy an ipod breakout board and solder the wires directly from the breakout to the connector on the appradio.
Posted Jul 13, 2012 · 10:59 UTC#3
aortiz....the video outputs look likes this way....sure ?
did you look the appradio cable ?
iphone connector one side...and other side, one wire for AV like a
