Wire Grounding?
By drozovs · Feb 03, 2007in Problems/Troubleshooting💬 2 posts👁️ 999 views
Posted Feb 03, 2007 · 22:54 UTC#1
I was curious if I can ground all three wires together in my '07 STI or if they each need to different ground screws?
David
Posted Feb 03, 2007 · 23:01 UTC#2
You can ground them together.
Just make sure you have a nice neat, clean ground.
If you are using the existing ground wire from the stock radio, you might want to use one, heavier guage wire and ground those three straight to the frame. Just drill a screw into an unpainted piece of metal.
