I've found that if you disable the use bluetooth for audio it will keep the bluetooth connected I don't know if anyone else was having the same issue as I of not being able to even connect the phone and access the app menu but it seems to have solved it for now. Just thought I would pass it along.
Possible bluetooth fix andriod
Unfortunately the downside to doing so means that you can't use your AppRadio as a speakerphone.
You mean the applications won't transfer audio? I figured that was done over the MHL connection.Unfortunately the downside to doing so means that you can't use your AppRadio as a speakerphone.
I mean that you can't use your AppRadio to make phone calls.
I think he means disable bluetooth audio streaming like mp3s and stuff. That of which would have nothing to do with phone calls.
That's kind of what I thought, but figured I just misunderstood. I know the Z130BT has options for enabling just phone calls, just audio, or both.I think he means disable bluetooth audio streaming like mp3s and stuff. That of which would have nothing to do with phone calls.
The only option presented to me for the AppRadio is "Audio" which is for phone calls. AppRadio doesn't support A2DP, so it's not listed on my phone.
