Black Screen - is my f900BT dead?
By juanreguillo · Jul 30, 2012in Problems/Troubleshooting💬 12 posts👁️ 1,464 views
Posted Jul 30, 2012 · 20:01 UTC#1
Hello. Some days ago, my f900bt European stopped. I only see the little lights on, at the beginning, and after that nothing. I can't access to test mode. I've tried in service mode, and update WINCE, but it stops when is writing at 5%.
I have read several people with the same problem, but no one solution.
Please, I ask your help. And please, excuse me, but my English is horrible.
Posted Jul 30, 2012 · 21:50 UTC#2
No not dead make sure you have correct wince files on formatted SD card try again
Posted Jul 31, 2012 · 15:16 UTC#3
Thanks, but I believe I've tried with 2.0 and 3.0 wince files, several times, and nothing. And I believe that the two files are readed, but not written (if wrong, i think should not read them). What could I do, then? Maybe prove with other files, and in that case, what files? Thanks in advance.
Posted Jul 31, 2012 · 20:49 UTC#4
Where do you live?
Posted Jul 31, 2012 · 21:40 UTC#5
Where do you live?
In Spain (Europe)
Posted Aug 01, 2012 · 21:35 UTC#6
What could I do then? No ideas, please?
Posted Aug 02, 2012 · 00:47 UTC#8
Should have everything you need.
Posted Aug 02, 2012 · 21:49 UTC#9
Thank you, tail24, but unfortunately, the problem persists. I've stopped at the beggining of the process. When I begin to update, the first sd card is readed, but when is writting, can't continue more than 6%. I guess it can't be solved.
Posted Aug 02, 2012 · 22:07 UTC#10
Try different SD card.
Posted Aug 02, 2012 · 22:22 UTC#11
And how how should be the card?
Posted Aug 04, 2012 · 21:20 UTC#12
I've tried with a different SD card. Same results. :-(
