Please pardon my ignorance, but I am new to the whole aftermarket stereo field. I just had an X940BT put into my '10 Ram. It was installed by a national stereo chain, and I asked them to bypass the E-Brake. What they did was to put a 40AMP relay in the wiring, but it did not over ride the speed monitor, so my video and certain nav features still cut out when I start driving. Is anyone familiar with what exactly they did, and can I just move the mute wire up and ground it to unlock everything, or should I pull out the relay and run the bypass like has been described at length? I see where the e-brake wire plugs into the 40Amp relay, then it looks like a ground that jumps between 2 terminals, and a dark blue wire on the 4th terminal, but I'm not sure where that goes. I can snap a pic if that would help.
Thanks.
Dave
