z1 BT upgrade
By clk · Aug 01, 2012in General💬 5 posts👁️ 1,681 views
Posted Aug 01, 2012 · 04:57 UTC#1
Hi everyone i have been reading that there is a upgrade for the z2 BT upgrade the thread said only for Z2. i was wondering if there is a BT upgrade for the Z1 and if some one can point me in the right dirrection thank you. i already upgraded my Z1 to the Z3 upgrade and have done the 2wire bypass.
Posted Aug 01, 2012 · 05:13 UTC#2
Then you no longer have a Z1, you have a Z3 and have no need for the BT update that came with the Z2.
Posted Aug 01, 2012 · 14:41 UTC#3
When i upgrade my z1 to a z3. Will i be able to stream music via BlueTooth? Also will i have to do the bypass again. it already works on the z1.
Posted Aug 01, 2012 · 15:07 UTC#4
No, you won't be able to stream with the standard ND-BT1. No, you will not have to do the bypass again.
Posted Aug 02, 2012 · 05:26 UTC#5
thanks alot guys you are the best keep up the good work that makes Avic411 the best
