Back-up Camera Question
By bigmac15 · Aug 20, 2012in Problems/Troubleshooting💬 3 posts👁️ 2,463 views
Posted Aug 20, 2012 · 16:24 UTC#1
Hi,
I found a reverse camera lying around in my house that wasn't being used so I decided to try and hook it up to my d3. The camera was made to be hooked up to a small monitor that it came with, which I don't want to use obviously. The only issue is that the camera has a red wire for power, black for ground then a 3.5mm headphone jack which was supposed to be used to connect the camera to the monitor in the corresponding 3.5mm jack. The d3 reverse camera input jack is an rca plug. I'm just wondering if it would work to just get a 3.5mm to rca adapter and hook that up or if I'd have to do any other wiring?
Thanks.
Posted Dec 31, 2012 · 02:25 UTC#2
Any luck with this?
Posted Jan 01, 2013 · 23:15 UTC#3
try what you said and if it doesnt no harm done :)
