do these require special plugs?the aux input located on the front wont play my ipod.tried 2 diff cords and no go.also tried running my ipod from the audio input located on the wire harness and got nothing.any ideas?
f700bt aux input and audio input wont work
Set AV2 to VIDEO.
And that will play music?any ideas on why the auxiliary input won't work?and doesn't require special pioneer cords?
It won't work because you haven't turned it on. VBlue told you change the setting and it'll work.
I turned the AV input on and nothing.and it didn't give me an option for the auxiliary input.
And you have the Red yellow white av cable connected?
Set AV2 to VIDEO.
Did you do this???
There is no AUX input. There is AV2.
What's the plug on the front for?I gonna open it up again this evening,ill repost what it does or doesn't do then.
It's a 1 cord av in.
The input on the front is AV2.
I there any way to play music using the Bluetooth?
No.
