z120BT Largest SD Card???
By scotto2323 · Aug 24, 2012in General💬 5 posts👁️ 1,846 views
Posted Aug 24, 2012 · 23:04 UTC#1
What is the largest SD Card a z120BT will read? The manual looks like it says 16GB SDHC, but I someone said they used a 32GB card in another post. Can anyone confirm what works for me?
Posted Aug 25, 2012 · 00:03 UTC#2
need that answer as well
Posted Aug 27, 2012 · 13:15 UTC#3
No one here is using SD cards? I am currently using 8GB so I can confirm that works. No one else with higher? I realize I can get a 16GB for only 10 bucks but would rather buy a 32GB for a couple bucks more if its gonna work.
Posted Aug 27, 2012 · 16:33 UTC#4
The z120 card spec is FAT 16/32 so you should be fine with a 32GB card. I'm using a 32GB card in my x930 that has the same specs and work no problem. If your concerned buy the 32 somewhere you could return if it doesn't work. I'd suggest a fast (class 10) card for fast performance when filling the card.
Remember that there is a limit of 300 folders 2500 files. Anything more it just won't show the files / folders.
