This seems to have just started but now everytime i use waze navigation, my keyboard ends up missing. Not only on waze but my entire iphone! Its the only program that seems to be doing this. Anyone else having this issue? Any resolution?
Problem with WAZE
delete the app, and reinstall...
for the keyboard...i didn't try it
i have the issue of the keyboard shows up but will not take any input.
will try deleting and resinstalling the app
thanks
JJ
same problem too actually...have to take control on iphone, but i remember something on waze fonction ...
do you remember the message saying if you are driver or passenger...maybe it's due to that....( i don't believe, but it could be normal...)
i'm still having issues with this!!
i can't input a postcode as the keyboard does not come up..... the rest of the buttons work.
i have to input the postcode on my phone before getting into the car, save as a favourite and then load it up from the favourites when running on the radio!
has anyone resolved this yet???
JJ
i have the same problem!
I have iphone 4s with
latest 6.1 ios, latest version ob app radio app and latest version ob
aupeo and waze - both apps show only a part of the screen ![]()
Anyone have a fix? its still happening.
I was having this with the EZTouch app as well. I then got an iPhone 5 and couldnt use it with AR2. Now with the iPhone 5 update, I can use AR2 again. But some of the apps dont support the new method of connectivity (or have issues trying to do so). So will be interesting to see if this issue still exists.
But I dont think it is exclusive to Waze.
If you have a 4s or a 5 you can actually use siri to input your directions. Simply say "take me to (insert address or contact) via Transit" and siri will launch a screen with all your alternative nav apps that you have installed. Click on waze and your iPhone will send the directions to waze directly.
waze still being a PITA
and aupeo! wasnt aware of the issue of lack of connection until i raised it with them. update coming soon hopefully.
JJ
WAZE seems to be fixed!!
had to delete app, reinstall, re-register, accept terms, plug in and allow in car control
keyboard works
layout is slightly different
JJ
