Avic F10BT > 99% installed "wrong sd card insert right sd"
By Autocadster · Sep 01, 2012in Problems/Troubleshooting💬 21 posts👁️ 7,719 views
Posted Sep 01, 2012 · 13:24 UTC#1
Hello
Today I tried to update my Pioneer Avic F10BT, with this package "CNSD-210FM for Pioneer AVIC F10BT/F20BT" it went well with the first system update, but the update from SD1 reached 99% and then came the error "wrong sd card insert right sd" no matter what I do, it comes with" wrong sd card insert it right" :o/
Anybody know what I can do?
Edited Sep 03, 2012 by Autocadster
Posted Nov 04, 2012 · 11:14 UTC#2
I' have the same problem with F10BT
how did you solved it?
Thanks Andrea
Posted Nov 04, 2012 · 15:12 UTC#3
something is corrupted or not copied to your sd card again
reformat your sd card and recopy the files from the update to the sd card and try again
Posted Nov 04, 2012 · 15:32 UTC#4
I'have retry tree times reformat fat32 copy,also shop new sd,
but the same message
Posted Nov 04, 2012 · 15:36 UTC#5
I used sdhc 8gb 4gb but no micro sd
can this be the problem
thanks Andrea
Posted Nov 04, 2012 · 15:41 UTC#6
supertestmode.zip
Put this TESTMODE.KEY on your update sd card.
(if you dont know how to navigate file manager in testmode, search for "avic testmode" video on youtube)
well you can try this, but no guarantee it will work:
1. boot up with sd card inserted. unit will startup in testmode, go to file manager
2. remove the file USER\SYSTEM\RENEWAL\Progress.dat
3. remove file SD\TESTMODE.KEY
4. restart unit. unit should restart upgrade from 0%
Edited Nov 04, 2012 by pionara
Posted Nov 06, 2012 · 18:01 UTC#7
Today I did the suggested but the message is the same sd wrong card
you may not have properly installed the crack?
I'can back at the first update folder AVICZ110
thanks Andrea
Posted Nov 06, 2012 · 20:24 UTC#8
To go back I'copy PRG0 IN PRG1?
sorry but I'm desperate
Very thanks Andrea
Posted Nov 06, 2012 · 21:39 UTC#9
do same instructions as my earlier post #6, except in step #2, delete USER\SYSTEM\Download\StartKnd.log
This should kick out of upgrade mode and back to original mode. Then recopy all files to new sd card. Then try upgrade again.
Edited Nov 26, 2012 by pionara
Posted Nov 07, 2012 · 19:00 UTC#10
pionara
very thanks for your patience
tha basic funcional of radio is ok (navi not work) but the update failure , have same problem sd wrong.
I also replace the file in the folder USER/PRG0/APL RenewalIFLib.dll 68,5kb (copy from avicz110 folder hack 1.001)
still have sd wrong sd.
I'm sure SD1 it is not corrupt,I downloaded the file again
thanks andrea
Posted Nov 07, 2012 · 20:23 UTC#11
is there a "checkmd5.bat" file on the root of the sd card?
Run this and look at the output (it will verify all the files in the sd card) on your pc before trying to upgrade unit.
Posted Nov 08, 2012 · 07:05 UTC#12
I check all file with 0 error. "md5summer.exe"
Is it possible that the cause is a failure update with first hack AVICZ110?
Posted Nov 08, 2012 · 15:39 UTC#13
did you copy any new files into SD\Update - that is wrong - you did not follow instructions
Do not change the files in Update
You only change the RenewalIFLib.dll that is on your unit
Posted Nov 08, 2012 · 16:06 UTC#14
I check all file in sd card all OK
I wonted to know if the problem the wrong sd card message may be caused by the first update 1.001.
I've tried to replace renewallflib.dll in the USER\PRG1\apl not work
Posted Nov 08, 2012 · 16:19 UTC#15
did you replace renewaliflib.dll with patched version of SAME version as 1.001 what is in your unit? or did you just download one from the internet somewhere and drop it in?
Actually, this should not matter. Once you enter password and unit reboots and starts upgrade, its not using renewaliflib.dll any more. Its just upgrading using files on SD card in Update folder.
As long as you did not change any files in Update folder and it passes CheckMD5.bat test, it should work fine.
Posted Nov 08, 2012 · 16:33 UTC#16
The file is patched from AVICZ110 hack v1
the check does this automatically between 98% and 99% during the update?
I checked on Windows PC
is wrong?
Posted Nov 08, 2012 · 16:34 UTC#17
is wrong?
Posted Nov 08, 2012 · 17:04 UTC#18
if update fails around 98-99 percent, it's usually because of bad/missing files on update SD.
I have for you 100% working solution:
1. Contact Pioneer.
2. purchase 2012 update for your unit
3. they will provide telephone support
Edited Nov 08, 2012 by pionara
Posted Nov 16, 2012 · 12:44 UTC#19
I solved
reading the file ALLDATA.VER with a hex editor I saw the list of files to install order, the last file
user / system / bg / opening.flg,missing in my SD1.
Added the file to 0 bytes, thanks to pionara,your edited file (VERINFO.DAT)is to update all
Thanks again Andrea
Posted Nov 16, 2012 · 14:18 UTC#20
many versions CNSD-210fm EU in the web,this file is missing.
especially those with a single rar file
Bye
Posted Aug 18, 2013 · 14:24 UTC#21
I solved
Thanks again Andrea
