AVIC-F40BT Testmode fixed firmware
By ktoto · Sep 01, 2012in Hacks/Mods💬 21 posts👁️ 41,086 views
Posted Sep 01, 2012 · 13:59 UTC#1
I fixed firmware for AVIC-F40BT (AVIC-F940BT) with fixed testmode.exe (now can do copy and paste).
If i am right that firmware possible to use like official firmware.
Posible to download here
http://narod.ru/disk...rmware.zip.html
But it not tested. Use it only in case that you know what you doing.
Edited Sep 01, 2012 by ktoto
Posted Sep 10, 2012 · 13:02 UTC#2
Here is updated firmware with cracked testmode. This Testmode have Copy/Past enable.
Do not use previous link.
Posted Sep 26, 2012 · 15:40 UTC#3
This Firmware work with AVIC-Z140 ?? Thanks.
Posted Sep 26, 2012 · 15:49 UTC#4
you dont need to flash new firmware, i found a way to generate "super" testmode key (aka Developer testmode)
supertestmode.zip
Posted Sep 26, 2012 · 16:44 UTC#5
welcome led0rub :) :)
btw you've got your username in polish lang? :D
Edited Sep 26, 2012 by condiczek
Posted Oct 02, 2012 · 23:39 UTC#6
ktoto, can you share the method you are using to extract and repack fw?
I have tried dumpromx, and it's fine for viewing in IDA, but cant repack w/dumpromx.
Posted Nov 06, 2012 · 18:39 UTC#7
supertestmode.zip
with the supertestmode i cant copy from sd card to folder Apl.
i mean Paste at Folder Apl
the Past Button are not activ. wath can i do ? i have an F930BT
Posted Nov 06, 2012 · 18:44 UTC#8
i search for LED0RUB_firmwareV2.zip
were can i load. please not depositfiles.
Posted Jan 20, 2013 · 22:08 UTC#9
OK are these the correct files for test mode?
file://localhost/Users/airbornediver/Downloads/testmode-1/63D21BEFE088433dBE3CF942347464C7
file://localhost/Users/airbornediver/Downloads/testmode-1/164C549550B84211BA8C4B84AC5C0081
file://localhost/Users/airbornediver/Downloads/testmode-1/738AE337FD024201A799B90250D6335A
file://localhost/Users/airbornediver/Downloads/testmode-1/66543C4BA1ED45d0AF57DB70682069AA
file://localhost/Users/airbornediver/Downloads/testmode-1/70560201322534565929232100000201
file://localhost/Users/airbornediver/Downloads/testmode-1/45487613469745412354668745684665
file://localhost/Users/airbornediver/Downloads/testmode-1/BAC66FE457CF4b43B9751BD370C0E8B2
file://localhost/Users/airbornediver/Downloads/testmode-1/CopyTool.exe
file://localhost/Users/airbornediver/Downloads/testmode-1/CopyTool.mscr
file://localhost/Users/airbornediver/Downloads/testmode-1/EC0BD4EA290F47628CE487FB2289AEF5
file://localhost/Users/airbornediver/Downloads/testmode-1/MortScript.exe
file://localhost/Users/airbornediver/Downloads/testmode-1/NNtestmode.exe
file://localhost/Users/airbornediver/Downloads/testmode-1/Utils/
Posted Jan 21, 2013 · 14:55 UTC#10
airborne - NO
testmode for these files is one "testmode.key" file on sd card - no folders
look for the supertestmode attachment from previous posts
Posted Jan 24, 2013 · 16:09 UTC#11
pionara, I have a z130bt with the updated 2012 maps and works great but the supertestmode will let me copy but it will not paste on the sd card. I'm trying to remove the caution screen. thanks
Posted Jan 24, 2013 · 16:24 UTC#12
It sounds like your problem is with the clumsy testmode user interface. Did you see Jason's video on using TestMode? He shows how to copy and paste files to the SD.
Don't be confused by his reference to "Condi's Hack Mode". What he is showing is the (Super)TestMode interface.
http://www.youtube.com/watch?v=ipoK6dfCp_Q
Edited Jan 24, 2013 by RonS
Posted Jan 24, 2013 · 20:18 UTC#13
As Ron mentioned, the interface is crap - but it's all we really have to work with.
you cannot overwrite a file via paste - you must delete a destination file first, then go copy the source and paste it to the destination folder
Posted Jan 24, 2013 · 21:39 UTC#14
Thanks ya'll that worked. Is there any hacks for getting the VR to work with gps ?
Posted Mar 16, 2013 · 02:43 UTC#15
I have the z140 with 4.001 does not let me past
Posted Mar 16, 2013 · 17:50 UTC#16
got it to work
Posted May 07, 2013 · 21:59 UTC#17
I had totally bricked my AVIC - F930BT - used that video as a guide. and used this software to reload my system - After a few goes i got it correct.
Use this link - it may take a while to start : http://avic411.com/index.php?app=core&module=attach&section=attach&attach_id=14482
Once saved - remove the .txt from the file and then it should load in your torrent downloader. Hope this helps
THANKS A MILLION GUYS FOR ALL YOUR HELP !!!!!!!!!!!!!
Edited May 07, 2013 by rocketrossuk
Posted Aug 17, 2013 · 19:46 UTC#18
I deleted thinking i can past now I am screwed. Any suggestions ? Is there any way to get to the windows OS
Posted Sep 09, 2015 · 05:16 UTC#19
hello all, I updated my f940bt somehow with the 2013 files. Now I want to do the same with the 2015, but I am completely lost. I do have a the password for the (Flomsen)zip file , but that already seems to give some errors. It does unpack something though.
But then I go to the instructions.. And I see testmode. No clue how to run that. Can someone give a more extensive manual how to do this? Also the files that need to be changed; iuf these are suppose to be in the zipfile, its not there.
Posted Feb 15, 2016 · 15:25 UTC#20
with this hack it's impossible to undo the hackmode. the f930bt restart and stuck on pioneer navgate image and do nothing....
Posted Aug 01, 2017 · 21:20 UTC#21
How do I download the file
