New Traffic Tuner will not work on a Z110 Upgraded to 2012 navteq map
By jmtorres · Sep 01, 2012in General💬 10 posts👁️ 3,067 views
Posted Sep 01, 2012 · 20:29 UTC#1
I have a z110 upgraded to z120 than upgraded to 2012 navteq map. I removed the msn tuner and installed the new traffic tuner and it does not work. It goes into a loop when starting up and continues rebooting. Anybody have any help on this topic.
Posted Sep 07, 2012 · 02:02 UTC#2
My unit didn't have any issues, granted I haven't used the traffic tuner yet. Try unhooking it and see if it continues.
Posted Sep 09, 2012 · 23:24 UTC#3
Trust me the minute you hook up the tuner the system will start rebooting on its own every two to three seconds. As soon as I took it off it was all good.
Posted Sep 11, 2012 · 16:57 UTC#4
No disrespect, but may I ask if you upgraded your Z110 with the correct upgrade? There are two versions; one for Z110/Z120, and the other for Z130.
Also, did you try to upgrade the HU with the new tuner installed? Maybe it is expecting to see the old tuner, and goes into a loop because you installed the upgrade with the old tuner. Im just thinking out loud.
Edited Sep 21, 2012 by IdentityWithheld
Posted Sep 21, 2012 · 01:47 UTC#5
Actually it's one upgrade for Z110BT/Z120BT and a separate one for the Z130BT...
Posted Sep 28, 2012 · 22:51 UTC#6
This sh ould be sticked and or made in a general forum..
Due to the fact is ive been on this forum for the past couple months and was able to get my z110bt to 1.001 and dats it.. the short fuse procedures is all scattered also for It seems that the cracks are avail for more than one upgrade too, or I am wrong?
we need to know the best hacks and or upgrade for the z110bts and the general progress ion of hacks and upgrades.
For example Im in Italy with the stateside z110bt and would like to upgrade PLUS load the eu maps while im out here.
Reading thru here it states to short fuse a 30 piece torrent and that has 18 pages of questions and no clear up procedures and or suggestions.
Edited Sep 28, 2012 by wgreen
Posted Oct 04, 2012 · 08:17 UTC#7
Mine works perfectly with the new update using a 110bt +traffic tuner and 2012 maps.
Posted Oct 13, 2012 · 01:43 UTC#8
Dirtmaster, can you share with us what traffic options are available after the 2012 map update ?
I heard that many of the traffic conditions and reroute options are gone..
Pete
Posted Jan 24, 2013 · 19:11 UTC#9
I'm in SoCal, with a z110bt that was installed and updated to 2011 (and parking brake bypassed) when I bought the vehicle.
I updated the firmware and maps to 2012, and the thing seems to route around traffic tie-ups somehow - it took me off the 5 and onto the 110 yesterday when the 5 was clogged and the 110 was clear. I don't know if the system has a traffic tuner installed or not, though the fact that it took me on a longer route (with less traffic) at least twice makes it look likely.
How can I tell if I have the tuner installed? On the Home|Directions screen there is a touch button for "Traffic", but I don't know that it does anything.
Posted Jan 24, 2013 · 20:24 UTC#10
when you are int he traffic menu, you can select traffic providers (and after your radio has been on for a few minutes) you should see one or more FM frequencies to choose from in the list. If it says no traffic providers, then you are either not in coverage, or dont have a traffic tuner connected to the back. If you bought a Z110 when it came out, and have not since installed a TMC traffic tuner, then you probably dont have one.
