Ok this is for a 1996 honda civic dx, I already know where to find the wire and what color it is. Its under my hood and its the blue/white wire.
My question though is what is the ideal way to tap into the wire....the easiest that is....?
Is it okay to cut the vss wire? (then do the stripping of the ends and then tap into it....and solder)
or...
Take a knife (exacto....switch blade...w/e) and NOT cut the wire, BUT slice around the plastic covering (or jacket...is that what its called?) in two spots...probably an inch, or inch and a half apart then slice the plastic covering following the wire connecting the two portions of the slices i had previously done and peal the covering off, without having to cut the wire.
This also goes for the break wire as well...are these methods okay when it comes to messing around with the VSS wire? Sorry if its a noobish question.
Also what does it mean to connect the brain to a constant and a switched 12 volt power source? and how do i do that?
Any help is much appreciated.
