Hey guys,
1stly im new to all of this and i may very well have done the "wrong" thing but it seems to be working just fine and is a common issue...
After much screwing around with different things I found that if you replace the new "SCHEME" zip files that are contained in MYFLASHDISK/APL2/IGO/CONTENT with the same scheme files that can be found in the year earlier in Pioneers version 2.06 factory download available on their site that for some reason almost 75% of the street signs will now appear at all zoom levels up to 1500 feet.
Its not quite the same amount as appears in the original 2.XXXX versions but im running 3.1 on a F500 and this really works for me.
Maybe someone that really knows what they are going can have a look in these files and see if they can crack it to get it back to 100% of the street names found in 2.XXX?
Hope this helps!
Malcolm
