My avic 110bt is constatly rebooting after the 2012 firmware update that i purchased off pioneer..it goes to the language screen then reboots itself..I had installed the 130 update a couple of months ago and no problem..pioneer is telling me that the language software seems not have installed when i called..is there anyway to where i can try to fix it on my own instead of sending it back to pioneer and also if i do is there anyway they can tell if i had installed the hacked version of the avic 130bt update?? thanks
CONSTANT REBOOTING AFTER 2012 UPDATE ON AVIC 110BT
if you purchased the update and your unit stopped working after the update, I would say you have a pretty good case for them to fix it free of charge. Likely they will just manually reload the latest software, etc, or maybe replace with a refurb unit. You would need to get Pioneer to commit to this, but seems like you should have a good stance.
Yes you can probably fix this on your own with testmode, but you REALLY be going into "void your warranty" mode with this one.
Did the update go ok? The update should have upgrade OS, replaced the program, installed new maps, etc. There should be nothing running from original/old software. If something is missing, I would suspect something went wrong with update, hence the first point.
i fixed it..i had to disconnect to power from the back of the radio and it worked..it would be nice if pioneer could have told me first before...thanks tho for the help..
Any chance of you posting the install files? There are Z130 updgrade files posted but not the Z110/Z120 upgrade, so I thought I should ask.
Sounds like a problem I've see in Windows more than once.
