X920BT Bluetooth with IPhone5
By Major_Malfunction · Sep 23, 2012in Problems/Troubleshooting💬 2 posts👁️ 1,328 views
Posted Sep 23, 2012 · 19:29 UTC#1
Anyone else having Bluetooth issues with a X920 and IPhone5 ?
I am able to play music over Bluetooth just fine
But when using phone the call volume keeps going from low to high
And some times cuts out for 2 or 3 seconds
The callers are able to hear me just fine however
Works fine with IPhone4 and 4S
Only have this issue with IPhone5
Bluetooth firmware on unit is from the last 2011 map update
Tried looking for a newer firmware but couldn't find anything on Pioneer website
Posted Sep 25, 2012 · 14:17 UTC#2
Did a little playing around with this when i had some free time
If i turn off LTE the calls sound fine
If i turn back on LTE i still have the issues hearing people while on a call and the volume going up and down.
This even happens when i am in areas where LTE is not available
I have the same issue when i connect to the Jabra hands free in the wifes van so i am assuming its not the AVIC at fault.
This only happens using a BT device calls on the phone sound fine with LTE turned on.
So for now i will just leave LTE turned off until Apple comes up with a fix for this
