Hello everyone,
I'm attempting to wire a reverse camera to my X9310BT (Subaru OEM version of a X930BT). I've got everything sorted out except for the reverse signal. The Subaru harness does not have matching colour codes when compared to the Pioneer installation manual, and the Pioneer manual only says to hook the reverse signal up to the violet/white wire - not the actual pin number in question.
I found this diagram:
Is it correct for a X930BT? This is from the FAQ for the F900BT on this site (in a post from 2009).
I think I hooked the signal up to pin 13 or pin 11 - if it's on 13, and the above diagram is correct, that's obviously wrong (power antenna). If I hooked it to 11, then it should be working... and it isn't.
I can get the camera picture to come up if I tell the unit to look for ground on the camera settings page, then restart the unit (power cycle) - this means my camera is OK and it's just the reverse signal that isn't working for me, obviously whatever pin it's looking at isn't receiving voltage.
Help!
