Help! "Program startup error" on x920BT
By Zorn · Sep 24, 2012in Hacks/Mods💬 11 posts👁️ 2,228 views
Posted Sep 24, 2012 · 23:30 UTC#1
I used the automatic RenewelFL patcher thing, so I can start to upgrade my maps. It said everything was replaced successfully, but now anytime I try to start up the unit it just gives a black screen with "Program startup error" Anyone know whats going on?
Posted Sep 25, 2012 · 00:07 UTC#2
dont panic ;) fix done :)
Edited Sep 25, 2012 by condiczek
Posted Sep 25, 2012 · 00:14 UTC#3
Yeah, Mine is all hosed. How are we going to fix it when we can't get the door open to replace the SD Card?
Posted Sep 25, 2012 · 00:16 UTC#4
download v1.1, unpack, dont forget to put dll also in SD,
you can get out SD - just push "open" button for 5s.
Posted Sep 25, 2012 · 00:24 UTC#5
Im putting everything on a new SD. Hate running back and forth.
This is what I have done.
1. Put The new 1.1 on root of SD card
2. Put the z140 Files on SD Card.
Is that all I have to do?
Edited Sep 25, 2012 by KraziJoe
Posted Sep 25, 2012 · 00:28 UTC#6
i dont understand, whats the state of your device now?
have you used RenewalIFLib utility? have you used after that new v1.1?
Posted Sep 25, 2012 · 00:31 UTC#7
error message "Program Startup Error"
I have not retried. You may have replied before I changed what I need to do.
I am trying to update my 110 to the new maps.
I tried the old 1.0 version and now have the error.
To do it all automated what is the exact method?
Posted Sep 25, 2012 · 00:34 UTC#8
1stable download v1.1 http://avic411.com/index.php?/topic/35267-renewaliflib-auto-replacer-v11-fixed-ver/#entry255975
unpack to SD,
copy RenewalIFLib.dll to SD,
put to device and wait for finish.
after that put map update on SD and go further.
Posted Sep 25, 2012 · 00:37 UTC#9
1stable download v1.1 http://avic411.com/i...er/#entry255975
unpack to SD,
I guess I missed the part on where I get the RenewallFLib.dll from. I thought this automated it? I am lost now.
Do I put the DLL file from the downloaded 140 files? Or from my unit?
Posted Sep 25, 2012 · 02:09 UTC#10
Dude. Put the cracked dll in there. The purpose of this program is to copy the dll to the unit for you so you don't have to play with test mode.
Dude you're so lost. Read up in the other thread to get a good idea before you f** things up
Posted Sep 25, 2012 · 02:12 UTC#11
I figured it out. Too many changes and if you come in at the end you see too many things.
Put in the Cracked DLL from post 12. Now I can't get the update to run. on my 3rd cif file. After this I am gonna just out back the original and hope it works.
