Locked out of some Settings, x940bt
By coryjac0b1 · Sep 27, 2012in Problems/Troubleshooting💬 4 posts👁️ 1,110 views
Posted Sep 27, 2012 · 20:29 UTC#1
Just got done installing most of the components for my x940bt. Everything works great, except that I am locked out of all the Blutooth, and the naviigation settings. The parking brake wire (lime) is not hooked up yet. Is this the reason? Also i plan on doing the bypass but just have one question, after you move the "mute" (yellow) wire, does it get wired to something, as of right now it is not wired to anything in the car.
Thanks.
Posted Sep 27, 2012 · 20:50 UTC#2
I'm pretty sure that is the case. Without the bypass I'm 99% certain that you cannot add destinations for GPS or configure BT devices. Seemed to be a common complaint that the radio is crippled without the bypass.
Do the bypass and I can assure you that it will open up.
Posted Sep 27, 2012 · 22:49 UTC#3
Yes, just did it and it unlocked all the other options and settings.
Posted Sep 28, 2012 · 00:24 UTC#4
Now just don't drift off watching a movie while driving.
