AVIC F900BT reboot issue, while driving
By vexen1972 · Sep 29, 2012in Problems/Troubleshooting💬 16 posts👁️ 3,021 views
Posted Sep 29, 2012 · 00:59 UTC#1
Just installed my AVIC 900BT in my 2010 chevy Tahoe using the PAC OS-4 Radio replacement Interface. Everything worked or seemed to work, here is my issue: when the vehicle is sitting still, it stats up fine, once the vehicle start moving forward, the radio is constantly rebooting until I come to a complete stop. Before I go tearing the whole system down, I would like to know where I went wrong with the installation.
Posted Sep 29, 2012 · 02:07 UTC#2
Just figured it out, it's my antenna...great, no GPS. Now to eBay I go to find a replacement antenna
Posted Sep 29, 2012 · 02:44 UTC#3
They are cheap bought one for like 25 a few years ago after I accidentally ripped mine out
Posted Sep 29, 2012 · 16:58 UTC#4
Yup, just bought one for 23.00, let's see what happens when it gets here
Posted Oct 06, 2012 · 03:28 UTC#5
Well my new antenna is installed and yet once I go over 15 mph , it starts to reboot........why,why, why ...any suggestions, could it be my vehicle speed sensor, I'm at a lost now... just checked my power harness, i don't have the Pink (CAR SPEED SIGNAL INPUT) could this be the issue?
Edited Oct 06, 2012 by vexen1972
Posted Oct 06, 2012 · 11:25 UTC#6
Did you run the reboot loop fix?
Posted Oct 06, 2012 · 18:36 UTC#7
No, not yet, downloading as I type, will do once complete...so will not having the Pink (CAR SPEED SIGNAL INPUT) cause any issues or is it not needed?
Posted Oct 06, 2012 · 22:15 UTC#8
Only issue it'll cause is slightly less accurate GPS
Posted Oct 07, 2012 · 01:50 UTC#9
what firmware do you have on the F900BT? Mine use to do that with the v2.x.
Posted Oct 08, 2012 · 03:28 UTC#10
I have the v2.x..., still need to run the reboot loop fix though
Posted Oct 08, 2012 · 20:26 UTC#11
If you upgrade it to version 3.X or higher it should go away (regardless of the "reboot loop fix"). If some strange reason it does continue to reboot after the upgrade, do complete wipe and restore of the unit (the step by step directions are on the forum).
Posted Oct 09, 2012 · 00:48 UTC#12
Fixed the issue!!, using test mode, I went in a deleted all the gps files, so far so good, had the truck up to 70+ and no reboot...fingers and toes crossed
Posted Oct 09, 2012 · 11:26 UTC#13
excellent. mine as well update as well.
Posted Oct 09, 2012 · 16:48 UTC#14
Good to hear! 8)
Posted Oct 11, 2012 · 00:25 UTC#15
too bad I now have two GPS antenna, but it's still working like a champ, love this site..thanks all for the help
Posted Nov 29, 2012 · 21:20 UTC#16
What files do you delete? I'm having the same problem and I delete 3 files and they come righ back.. I got the cd player for the nav and I can't use it
