Hey need some helpp
By underworlddon · Feb 07, 2007in Hacks/Mods💬 19 posts👁️ 4,412 views
Posted Feb 07, 2007 · 06:08 UTC#1
Hey guys this is my first time HERE i've tried lok in the forumm But havent quite got my answer.. Well to start off i jus bought a n1 with the n2 software .. off a person.. he said everything worked fine nothing is wrong.. so Coo it is true.. so now i installed it in my CAr... My problems aree Da installer says I DONt have a SPEED somthing In my Car too hook up the Speed sensor.. (is that true?) .... then wen its turn hook up the rca for my sub, and front and read speaekrs.. he says he canthook up the front ones because wen he hooks that up.. the rear speakers makes a Noiseeee.. can anyone tell me why that happened.. it never use to happen with my old deck.. and wen i drive after a while screen goes on that sign were i cant see video im guess its cause of that BYPASS thing.. now i wann know if there is anyone to bypass that wihtout actually sodering?? and finally i really dont know how to WOrk this thing but umm.. shouldnt there be a VOIce help while the navagation is on>> from the settin i turned voice help ON and stuff but wen i drive there is no helpp it jus shows on screen to turnn .. is there any wires i gotta hook up for tat?
Posted Feb 07, 2007 · 06:38 UTC#2
Anyone have an ebonics to english dictionary I can borrow?
Posted Feb 07, 2007 · 07:05 UTC#3
umm okay
Posted Feb 07, 2007 · 07:17 UTC#4
do you get sound playing regular cd?
Posted Feb 07, 2007 · 12:26 UTC#5
Year/make/model of he car would help a lot. We can't read minds.
Posted Feb 07, 2007 · 15:53 UTC#6
ebonics to english translater needed, anyone know where to get? I stopped reading after the second line.
Posted Feb 07, 2007 · 19:34 UTC#7
another indication that we are all getting old. When we need a translator to understand what these "hooligans" are talking about.
Posted Feb 08, 2007 · 00:05 UTC#8
sorry for the english . im not so good at it its like my 3rd language. but car is toyota tercel 1999 .. only the rear speakers play and when i plug the rca for the front speaker the back ones make noiseee
Posted Feb 08, 2007 · 00:21 UTC#9
I read this like 4 times, and I can't find anything useful to say.
Posted Feb 08, 2007 · 01:11 UTC#10
I gots been usin' dis here translator fo' years an' it still werkz well. and shit.
(I have been using this translator for years and it still works well.)
http://joel.net/EBONICS/translator.asp
Posted Feb 08, 2007 · 01:16 UTC#11
Ok I think I'm beginning to understand. Now what aftermarket equipment do you have installed in the car. IE amp(s), speakers, subs. Please be as detailed as possible. If there are new speakers in the car, was new wire run to each speaker, or was the factory wiring used?
Posted Feb 08, 2007 · 01:48 UTC#12
okay sorry again to people who didn't get what im tryin to say.. im not so good at this but yah... Before i installed the pioneer n1, all speakers were working fine. I have a Rockford Fosgate p10002 AMp with 2 12inch P3 and 4 JBL speakers 2 for the front and 2 rear. the speaker are running from a 4 channel Kenwood amplifier. and from the amp the rca to the unit. so right now only the read speakers are working. When i plug in the front speakers the REAR speakers makes a weird noise and at times when i turn up the unit to like 40 Volume the rear speakers makes some Distortion noises like little buzz noises.. and also i wanted to make sure .. is it true my SPEed sensor for the nav can not be hooked up? because my car Doesnt HAve some switch?? thats what the installer told me.. and yah that should be it except i dont get voice when the nav is on, for example it doesn't say make a left or right turn.. I've tried to explain and write at my best i hope people can understand. and thanks to everyone who is ttrying to help me out thanks you again
Posted Feb 08, 2007 · 01:55 UTC#13
I dunno about your car's Speed sensor (it should have one though), and maybe cntrylvr will know more about your problem...
BUT.... did you use the RCA outputs from the AVIC to go to the RCA inputs on the amp? Line level to line level? Or is it hooked up at speaker level to the amp? From what I can tell the RF10002 is a 2 channel amp... so I'm guessing it should only be used to power a right and left channel? Front or rear but not both? someone jump in here.
Posted Feb 08, 2007 · 01:58 UTC#14
Oh and as for your voice with nav... you can set up which side it comes out of, but I assume it only comes out of the front speakers. If you don't have ur amp properly hooked up, it won't make a sound.
Here's my uneducated guess. You ran the rear out or the non-fading output RCA cables to the amp, then doubled the amp up to 4 speakers? That would explain why you aren't hearing voice guidance, and possibly why you are having sound problems? I'm not an expert, but thats what I'm gathering here
Posted Feb 08, 2007 · 01:59 UTC#15
The reason you're voice prompts for the navigation aren't coming up is because your front speakers aren't working properly. First things first make sure the rcas at the amp are indeed plugged into the front and rear inputs of the amp, NOT the pass through. Next since the rear speakers are working try unplugging the rear rcas from the rear output of the avic and plug them into the front output of the avic. Do the rear speakers still work plugged in like that? If so then something is wrong with the front rcas.
The vss wire your installer is talking about is not needed, it just provides a little more accuracy for navigation. The wiring I have doesn't list the wire color for your car. The ar more than liekly has one though the installer was probably to lazy to go looking for it.
Posted Feb 08, 2007 · 02:00 UTC#16
nvm i forgot to read the part about the 4ch amp. lol my bad
Posted Feb 08, 2007 · 02:41 UTC#17
okayy i have tried remove the RCA and put it vise versa and it worked, and thanks for letting me know only front works with voice which is cool.. now my prob is when i turn up the VOlume over 35 - 40 the vocal speaker makes distortion noisee .. why is tat happening? and i installed the n2 Softwaree and i've notice sometimes my unit Freezes.. i cant close it nor i can press any button i would have to Turn of my Car completely then start again for it work .. does that happen because of the n2 software? or is it somethign else.
Posted Feb 08, 2007 · 02:57 UTC#18
It probably something else causing the freezing. As for the distortion thing, I'd have to say that's probably go something to do with the gains on the amp being up too high.
Posted Feb 08, 2007 · 03:05 UTC#19
oh okayy .. i think im gonna take it to one of those best buy Pro installer and let them take a look
