Anyone using the PAC Audio RP4-VW11 (RadioPro4) harness with their headunit?
I've got an issue where the headunit is not staying turned on in the ACC key position (key still in ignition, but not in ignition position). It only turns on and stays on in the "ignition" position.
I've connected the red wire on the RP4-VW11 unit to the ACC red wire on the headunit wiring. I thought that should be about it, but I guess not. The headunit turns on when I turn on the car, but as soon as I turn off the car and leave the key in ACC position, the unit turns off as well.
I'm trying to have the headunit on in the ACC position so I can use it when parked without leaving the engine running.
Oddly enough, I had an easier time doing the bypass than something seemingly as simple as this.
