Orange/White wire "To lighting switch terminal" to which wire on my harness?
By EvanVanVan · Oct 18, 2012in AppRadio, AppRadio 2, AppRadio 3💬 4 posts👁️ 15,298 views
Posted Oct 18, 2012 · 18:31 UTC#1
I'm using a Metra 70-2002 harness to connect to my stock Saturn SC2 harness. From the Pioneer manual it has one Orange/White wire "To lighting switch terminal.". But the Metra color code has two wirea I guess it could be, "Illumination - Orange" and "Dimmer - Orange/White."
I've tried connecting the AppRadio's Orange/White to both the Orange and Orange/White wires of the Metra harness but it seems that the backlight on the radio only comes on when I turn the headlights off. When I turn them on the radio gets so dim it's barely visible.
Any ideas which is the correct wire? And is the stock brightness supposed to be as low as it seems?
Edited Oct 18, 2012 by EvanVanVan
Posted Oct 18, 2012 · 18:38 UTC#2
It's working as intended; brighter when the headlights are off, dimmer when they're on.
You can adjust the brightness for each "mode".
Posted Oct 18, 2012 · 18:44 UTC#3
Ok, thanks. I forgot that it's supposed to be dimmer when the headlights are on and it's nighttime out. Thanks again..
Posted May 08, 2022 · 23:29 UTC#4
So i am using this in my shop. Will i have lights if i dont hook up orange/ white at all? Since im running this off of 110--> 12v power source..i havent run into this issue before this particular unit running in this configuration.
