Does anyone know how to transfer the ENTIRE phone book from the Motorola Q without doing it one by one?
David
David
There was some software out (do a forum search to find it) however it did not support the bluetooth stack used on the Q (at least when I tried it). I ended up doing 1-by-1 at stop lights and when waiting around. Took me about 3-4 days to get 100-some in.
I just installed the BTB200 yesterday and was able to send my entire phone book in 1 shot. Make sure bluetooth is turned on in the phone first.
Hit Phonebook transfer from the function menu on the D3. Then hit start to put the D3 into receive mode.
On your Q go to Start / Bluetooth / BT Send Object and hit select.
Change the send object to contacts.
Hit Menu / Select all.
Then hit send. It will transfer all your contacts in 1 swoop. Hope this helps some people that may be confused.
