2007 Honda CR-V Wiring
By DMB#41 · Feb 07, 2007in Vehicle Specific Wiring💬 10 posts👁️ 2,015 views
Posted Feb 07, 2007 · 23:01 UTC#1
Does anyone know were I can find a wiring diagram for the 07' CR-V? I am getting ready to install this weekend but i am having trouble finding the info. i will need.
Or any install advice in general would be much appreciated, its been a while since i've installed a stereo let alone a nav unit.
thanks,
Matt
Posted Feb 08, 2007 · 00:10 UTC#2
BE VERY CAREFUL OF THE BEZEL AROUND THE DASH. You will scratch it if you dont take care to not scratch it, its easily done. especially on the top of the dash itself. other then that its a breeze. make sure you drill new holes in the factory bracket that holds the radio. and if its an lx model, then get the ex dash from the dealer, or i have 2 extra here. you wont need a dash kit for a double din, just the ex dash piece. the swi-ps integrates fully as well. You have to use a 5100 ohm resistor and connect it as described by pac but not hard at all. Reverse wire is in the drivers kick panel area, and vss i dont recall but can look up later
Posted Feb 08, 2007 · 00:41 UTC#3
First off thanks for the help/advice
It's an EX so that shouldn't be a problem.
The stock radio isn't square like the Z1 is, and neither is the stock opening?? I ordered this dash kit http://www.installer-data.com/item/disp ... it=99-7873
Are you saying I don't need the dash kit? or I don't need the bracket?
Since my stock radio changes volume with speed shouldn't the VSS wire already be attached to the stock radio??
Thanks again,
Matt
Posted Feb 08, 2007 · 00:44 UTC#4
sorry, i reread my post, you need the LX dash piece from honda for the ex, not the other way around. get the honda one, it looks nicer and is about 9$ at cost, so retail would be like 20 maybe. I dont know the vss though to be honest.
Posted Feb 08, 2007 · 00:49 UTC#5
ahh ok.. do you know of any pictures of it?
Posted Feb 08, 2007 · 00:54 UTC#6
no, just the microfilm thingy the dealer uses. its the piece that is just above the ac controls and below the vents. its a squarish piece like what you probably got already.
Posted Feb 08, 2007 · 00:56 UTC#7
the piece I have isn't a full square, its wider at the top than the bottom. Is that the piece?
Posted Feb 08, 2007 · 00:58 UTC#8
probably similar
Posted Feb 08, 2007 · 01:00 UTC#9
Ill order one from you.. do you accept paypal?
Posted Feb 08, 2007 · 01:07 UTC#10
NM the LX dash and the EX dash are totally different. I'll just try the one from installer.com and if it looks bad ill look for the lx piece.
thanks again!
