940BT GPS position error
By Nimbus117 · Oct 31, 2012in Problems/Troubleshooting💬 4 posts👁️ 1,319 views
Posted Oct 31, 2012 · 12:58 UTC#1
Hi Guys,
Is there anyway of correcting the GPS position so it shows the car on roads? The position on the map seems about 100 yards out and shows the car driving parallel to the road but not actually on it. I tried adjusting the position and direction in the settings but still cant make it onto a road. It's a bit rubbish!
Updated to 4.01 by the way.
Posted Nov 01, 2012 · 02:31 UTC#2
That occasionally happens to me when I first get started. I believe it is because it doesn't lock on to all three satellites. For me it always goes away after about five minutes. You may need to put your GPS antenna in a better location. Mine is on the dash under the windshield. It's pretty unobtrusive.
Good luck!
Posted Nov 04, 2012 · 19:42 UTC#3
Thanks, I changed the GPS aerial location and is much better.
Posted Nov 05, 2012 · 02:40 UTC#4
:mrgreen:
