Microbypass not working
By adefeatedman · Nov 06, 2012in AppRadio, AppRadio 2, AppRadio 3💬 6 posts👁️ 1,814 views
Posted Nov 06, 2012 · 04:30 UTC#1
Hello All-
I am coming from a 920bt which bypassed like a charm, but I cannot, for the life of me, get this microbypass to work. I connected the radio as I normally would, and then added the microbypass wires into the others. Was I not supposed to connect the parking brake wire coming from the car? Thank you in advance
-Jacob
Posted Nov 06, 2012 · 12:23 UTC#2
The microbypass I used hooked into the parking brake wire from the radio, not the car. As a matter of fact, all three wires hooked into the radio making it think the brake is on. I hope this helps, Jacob.
texbuck
Posted Nov 06, 2012 · 14:48 UTC#3
Thanks Texbuck, I'll try that tonight. The other wires connect to the ground and the remote amp turn on, I believe, and I don't think I can disconnect those from the car. However, I will disconnect the parking brake wire coming from the car tonight and see if that changes it. Thanks again man.
Posted Nov 06, 2012 · 15:38 UTC#4
please post back and let us know how it worked (or not), thanks
Posted Nov 07, 2012 · 02:30 UTC#5
texbuck
This worked, thanks texbuck! So fyi to others, do not connect the parking brake wire coming from the car. This may not be obvious to everyone, so it bears stating.
Posted Nov 07, 2012 · 12:55 UTC#6
You're welcome. I'm always glad to help.
texbuck
