F930BT superhackmode and no Past Button. Wy ?
By R-S-B · Nov 06, 2012in Hacks/Mods💬 10 posts👁️ 2,645 views
Posted Nov 06, 2012 · 11:59 UTC#1
i have no past button in the supertestmode.
i have make copy on sd card and want past in APL.
i have no Button "paste".
HELP me ......
Mfg
RSB
Edited Nov 06, 2012 by R-S-B
Posted Nov 06, 2012 · 15:03 UTC#2
I assume you mean "paste" - you might want to use "google translate"
Please search youtube "avic testmode" and watch those videos
Posted Nov 06, 2012 · 17:27 UTC#3
yes i paste i mean.
thank you.
wath can i do for copy from sd card to Apl Folder ?
can you help ?
Posted Nov 06, 2012 · 17:39 UTC#4
on youtube i find nothing wath can i use. :-)
Posted Nov 06, 2012 · 17:48 UTC#5
I am having a hard time understanding you but:
You will only see the paste button if you have "copied" something first.
Again, testmode file maintenance is very strange. You would need to watch some of the testmode videos to see how to navigate.
Posted Nov 06, 2012 · 18:58 UTC#6
verry happy...... :-)
please. rearly... i go on my sd card in an folder with sume Files. select all
and press copy.
after i go to Apl Folder on my F930BT and want paste. but past is not active button in the Apl Folder.
t makes me mad.
I have even tried to automatic copy of condis Hack to copy myfolder Apl.
REMOVE USER\PRG0\APL\Av1.exe
REMOVE USER\PRG1\APL\Av1.exe
COPY -c USER\PRG0\APL\Av.exe USER\PRG0\APL\Av1.exe
COPY -c USER\PRG1\APL\Av.exe USER\PRG1\APL\Av1.exe
REMOVE USER\PRG0\APL\Av.exe
REMOVE USER\PRG1\APL\Av.exe
COPY -rc SD\MikesHack\*.* USER\PRG0\APL
but the script starts not : ScriptExec.ini
http://www.roller-skate-berlin.de/wb/media/my_first_test.zip
look please....
i think i am an newbe.
i must learn sume...
best regards
mike
Posted Nov 06, 2012 · 19:35 UTC#7
Ok, this is a similar trap I fell into when trying to copy/paste files in testmode. Make sure you are navigating to the folders using the menus and not the home button.
For example, if you go to the sd card, copy the file and then press home to get you back out, that copy is lost. You need to copy the file, scroll up to the "..." to get you up to the parent directory and select that. Only then will the item actually stay on your clipboard.
Edited Nov 06, 2012 by thedmod
Posted Nov 06, 2012 · 20:55 UTC#8
also, regarding ScriptExec.ini. There are different versions of testmode.
There is "scripting" testmode.key, and original (regular "service" testmode) and then super ("developer" mode) of testmode
scripting testmode.key will not go into the testmode screen, but instead run script commands in scriptexec.ini. That version of the key is included with condihack 2.x+ or autoreplacer
Posted Nov 07, 2012 · 03:06 UTC#9
OK i understand.. i test it today. thank you first.
Posted Nov 07, 2012 · 03:08 UTC#10
thank you. i test today wath thedmod write. :-)
