hi,
The new firmware pioneer avicf940bt has you he an action (share) on the bypass?
I at present the firmware 4.0 and the vision of video DVD work perfectly by running (driving).
The firmware 4.01 is going to forbidden the function bypass ?
thanks,
hi,
thanks,
no bypass did not change in 4.01
same hardware bypass applies, or you can also do softmod
Thank you very much for the information.
I can past firmware 4.01 with my avicf940bt and keep (guard) the modification bypass for video DVD.
sorry, another question
the textbook of l 'update of pioneer, it is written
firmware 4.01 for AVICF40BT.
it is so ok for avicf940bt ?
file AVIC-F40BT_Ver4.01 in SD card
the pioneer does not make anything ? he sees SD card
but not update ?
thank you
No one has ever done an avicf940bt update?
the exact method?
Insert the SD card at what time?
When the pioneer is turned off, the SD card is in?.. .and then pioneer on it?
yes - your "application version" is 4.010 - the latest.
thanks.
The update is not starting after I put the SD card in. Do I have to replace some files or should the updat start automatically.?
Solved, now, it was alrady updated to 4.01.
I just installed a f700bt. The unit is running version 3.02. Will this upgrade work on f700bt? Thanks
