Hey
Is this normal that when you play a song from the SD card then switch the source (radio, even video from the SD) and then switch back to SD music then it doesn't resume where it left off, but instead takes the first song from the file directory and starts playing that. It also happens when I turn on the HU and the source is set to SD - results in hearing the same song from the beginning every time when I'm starting the car.
It's really annoying when I have searched out an artist I want to listen to, then switch to radio for news or whatever and switch back.
I'm using a 32GB Kingston SDHC card which is almost fully loaded with media. Navigating (or database generating) the SD can also get slow, but that's probably because of the size.
Maybe I should switch to a smaller card - 16GB maybe?
Any other ideas, experiences?
Cheers!
