FIXED!!!!!!!
I bricked my x940bt this morning when I was messing around with the files. I deleted the PRG0 AND I believed also PROG1on the unit using super testmode(file mantenance). I tried everything to get it back up. I have music but "No application program" error comes up. I tried installing FW4.01 and it did install but there are files missing in PRG0. I do have backup (NADA) but not sure how to copy it to the HU. I went under file maintenance test mode but could not get to my SD card to copy the files over.
I tried copying the Condi hack to get to file explorer but no luck. If I have directions to copy my backup I believe I can get it going again.
Any ideas to get it going?
Jimbo
Update:
I was able to install fw 4.01. It has prg1 on the HU but not Prg0. It will boot for a short time and I get to the map and then is reboots again.
EDIT:
I tried everything, If I can get PRG0 on the HU, I believe I can get it going. I even tried to update using Z140 update from 930 to 940 and no luck. It did not even started to copy files.
Any other ideas?
Can anyone make a scriptexec file to enable me to copy PRG0 and PRG1 to my HU for my 940?
That would an option!
