how do I take off the door panels to replace my front factory spkrs, also how do I get to the rears?
door spkrs....
I'm guessing you're talking about the truck in your sig.
front speakers
1. Carefully unsnap front edge of window/door
lock control panel, lift away, disconnect &
remove.
2. Extract (1) 7 mm hex bolt from underneath.
3. Unsnap side mirror panel, lift away &
remove.
4. Carefully unsnap door reflector & extract (1)
5. Lift up door panel, lift away & remove.
6. Extract (4) 5-1/2 mm hex bolts securing
speaker, lift away, disconnect & remove.
rear speakers
control panel, lift away, disconnect & remove.
3. Carefully unsnap door reflector & extract (1)
4. Lift up door panel, lift away & remove.
yup you got it right it is the one in my sig sorry
my rear doors don't have spkrs they are in the bottom of the C pillar actually down by the floor beside the rear seat. that trim panal should just pop out right?
Guess so, don't really remember for sure. Just remember if it doesn't seem like it's going anywhere when you go to pull it off, look for hidden screws, and other panels that might have to be removed first.
