enclosing camera module
By rmoral1 · Feb 08, 2007in Hacks/Mods💬 5 posts👁️ 1,753 views
Posted Feb 08, 2007 · 18:48 UTC#1
does anyone know if i wrapped the pioneer camera module(the little black box the camera plugs into) in a watertight bag? i have a small moisture problem in the door sill for some reason. the vehicle is a 2004 f-150 and i have read other people have this same issue.
Posted Feb 08, 2007 · 18:53 UTC#2
I don't know, did you?
Posted Feb 08, 2007 · 19:00 UTC#3
hahaha ooops i meant to say does anyone know if it would hurt the camera module if i wrapped it in a water proof bag. sorry i just woke up when i wrote that
Posted Feb 08, 2007 · 19:03 UTC#4
it shouldnt.
Posted Feb 09, 2007 · 04:09 UTC#5
To try and fix your leak, check your high mount rear break light. The factory seal sucks, especially if you are running your antenna wires out that way to your roof. I had the same leak in my truck and pulled the light, put down a bead of silicone, put it back together, and no more leak. Hope that helps some - Erik
