Subwoofer install/config
By busyychild · Dec 20, 2012in AppRadio, AppRadio 2, AppRadio 3💬 3 posts👁️ 2,087 views
Posted Dec 20, 2012 · 19:01 UTC#1
What are people doing for sub installs?
Can we use mixed wired lead and RCA outputs?
EX:
Door speakers: wired leads
Sub: RCA preout
Does the following settings have this effect?
Rear speaker: Full
Preout: Subwoofer
With those above settings, can I configure the High Pass ONLY on the door speakers (F+R wired leads) and the Sub Frequency ONLY on the RCA preout?
Edited Dec 20, 2012 by busyychild
Posted Dec 21, 2012 · 02:00 UTC#2
I'm not sure what you're trying to do. If you're adding a sub just use the sub preouts. High pass preouts are just if you're using an amp for the highs.
Posted Dec 22, 2012 · 05:25 UTC#3
Im assuming your using either the 01 or 02 variant since it only has one set of pre outs... if your into bass use the pre outs for the sub if ur into all roubd goid sound use the pre outs for the rears and use a line in covert for ur sub
