Appradio 2 not saving time/settings
By Hakannedjat · Dec 23, 2012in AppRadio, AppRadio 2, AppRadio 3💬 4 posts👁️ 1,011 views
Posted Dec 23, 2012 · 12:11 UTC#1
Hi all,
I've recently purchased an appradio 2, what's happening is its not saving any of the time settings or any of the settings for that matter, every time it's turned off and on again it reverts back to factory defaults and a 12:00 time.
Do you think this a unit specific fault? Don't think any of the wiring would effect this...
Thanks,
Hakan
Edited Dec 23, 2012 by Hakannedjat
Posted Dec 23, 2012 · 14:23 UTC#2
Are you sure you hooked up your appradio to a constant power source? You need both constant power for the memory settings and switched power for running the appradio itself.
Posted Dec 23, 2012 · 19:37 UTC#3
That may be why then, good point, I'll have to check that, thanks!
Posted Dec 24, 2012 · 14:36 UTC#4
Some vehicles have the iso wiring switched between ignition and constant, so you'll need to use a meter to make sure which wire is which.
