So, do you have an AppRadio 2 in your car and you got an iPhone 5 and found out you now have a $350 AM FM Radio with blue tooth phone, and everything else is gone? Here's a couple of quick videos I did to make the best of a bad situation. The first one shows how to direct connect your iPhone 5 or iPad 4th gen to the head unit and get back the video you lost and still charge your phone without using the 40 pin connector. The second video takes it to the next level by integrating an Apple TV into the car and stream wirelessly to the head unit, nice, but a little more expensive and takes a bit of tech skills to setup the router and AppleTV unit. But, the resluts are pretty fun and I'll show you how and what it costs and the parts you need to make it work. This method uses AirPlay, so iPhone 4, 4S and 5 will work with this, as well as iPad 2, 3 and 4. Enjoy...
