Avic 940BT & Audiovox Camera Problem
By DHusidic · Jan 07, 2013in Problems/Troubleshooting💬 2 posts👁️ 1,084 views
Posted Jan 07, 2013 · 02:30 UTC#1
I have an AVIC 940BT & Audiovox Camera, I got the radio to recognize the REVERSE signal and the radio switches over as it should. The problem I have is there's no image,at times there is and at times theres none. I've checked the connections and everything is connected.
Posted Jan 12, 2013 · 18:13 UTC#2
Are you sure the camera works. I've seen them directly connected to a monitor. You might try that.
Good luck!
