I've created the pictures folder on my SD card, added a jpeg picture in there and the unit does not show it when I go to select from SD! What am I doing wrong?!
X940BT Can't Change Splash Screen
Try some of the images users submitted here and see if they show up for you.
If they do, your picture might not be correct. (file size or height / width).
If nothing still try a different card if possible, or it might be your unit.
Does it not show the file name or the picture when you select the file name?
Nervosa also has a good suggestion.
download avic feeds:
http://www.pioneerelectronics.com/PUSA/Car/GPS-Navigation/Download+AVIC+FEEDS
and do it using the program.
thats how i did it.
u put ur sd card.
set the splash screen
save
put the sd in the unit
it auto detect. install and done
so I download to my computer, put sd in computer, set on avic then put card in radio?
yes
wouldn't work.. avic saves as bitmap but unit is telling me it needs to be jpeg..
Alright I figured it out. AVIC Feeds saves it to SD card UNDER a folder called PC. Open Up PC Folder DRAG PICTURES to the ROOT OF THE SD CARD and ITLL WORK!!
