Appradio 2 help
By Scotty2k3 · Jan 16, 2013in AppRadio, AppRadio 2, AppRadio 3💬 9 posts👁️ 1,936 views
Posted Jan 16, 2013 · 21:13 UTC#1
Just got appradio 2 for Christmas and having issues with it
I am trying to get my Samsung Galaxy s2 LTE HD or Skyrocket to work with it, I heard from users on the forums that it will work with the appradio. I bought this MHL / HDMI compatable cable, the phone recognizes it's connected but the appradio will not recognize the phone.
Factory reset will not work. The option is greyed out. Not to get into the factory reset but the OK button is greyed out even after all devices and music is shut off / disconnected.
I cannot preform a firmware update. It gives me a error saying cannot update at this time press the back button and try again. Reformatted twice on both mac and PC on fat file format with nothing else on the usb stick and still the same error.
I don't get full speakers when I am listening to my Ipod, I only get the front left speaker, and when I switch to radio I get all speakers. I checked my 4 channel amp and switched it to 2 channel and still only have 1 speaker for the front, and subwoofer when I select my Ipod, but when I select radio I get full speakers and subwoofer.
any help would be great as I am thinking that this is a returned car deck or a faulty one. Thanks
Posted Jan 16, 2013 · 21:56 UTC#2
seems that if you are in last android system (ICS 4), it's not working...info from pioneer france, in facebook
Posted Jan 16, 2013 · 21:58 UTC#3
Ok, so that explains the phone issue, now what about the rest of them ?
Posted Jan 17, 2013 · 20:38 UTC#4
1st, is the firmware size "almost" the same as described in "readme" info file ( pdf )
sometimes some kilobites can miss...
2nd, the problem with ipod and speakers is probably due to the connector "bad" plugg...look when you move the connector in the ipod if it get's better...
sometimes it happen the same to me due to my protecting plastic of the iphone...
Posted Jan 17, 2013 · 20:48 UTC#5
I usually disconnect the Ipod all the time, and the firmware is a couple of megabits like 18 I believe. Is there anyways I can see which verison is on the deck at the moment ? maybe it won't let me upgrade because they are the same verison ?
Posted Jan 17, 2013 · 21:21 UTC#6
good idea, maybe you are already "updated"
i don't know how the DA100 must be displayed...but compare to DA01...you see firmware version in general settings...
you must compare in a commercial "center" where the unit is...sorry i can't help more, i think all you did is quite right :/
Posted Jan 18, 2013 · 12:49 UTC#7
The updated firmware will display [CAUTION] in brackets when you enable the back up camera. Versions prior to 8.17 only showed CAUTION without brackets. You don't need a camera installed to do this. Go into settings and change the camera from "off" to either "battery" or "ground", then press the camera icon in the upper right of the main menu screen. The warning will then appear.
Also, your ipod cable might not be fully seated as yonel suggested. It is the same cable used for firmware updates, so if it's not fully seated, or just plain bad, it will not allow you to update your firmware.
Posted Jan 19, 2013 · 15:46 UTC#8
Ok I will look into it, My girl friend took my truck the other day and magically all the speakers are working now... so maybe It could be a plug issue at the back of the deck or maybe not seated... i'll have to dig into this more
Posted Jan 19, 2013 · 23:38 UTC#9
Just tried to try an update again and I keep on getting this stupid message with different usb sticks. "The Version up file can't be read. Please save only one verison up file to USB Memory. Press back key to return and try update again. " Now the only file that I have on there is the update file and it's the .hat file, and I formatted the usb with FAT format.
