For some reason, the map color profiles and the "LED" colors of my F90BT always reset when I turn off the car. Does anyone know why it would do this?
Posted Jan 16, 2013 · 23:02 UTC#1
maybe you dont have the BUP (yellow wire) wired to constant (battery) 12vdc?
I'll have to double check that wire, I didn't even think of that. It used to work just fine and then one day it started acting weird. Hopefully that's the problem.
EDIT: Hi, I'm new ![]()
Was there a solution here? I have an F910BT (AUSTRALIA) and after updating with hybrid 4 I've come across the same issue. Wiring is correct, checked twice but the unit loses map configuration every boot, button illumination colour every third or 4th boot but keeps radio stations and eq settings...
