Issue with rolling back to appradio 1.8.2. from 2.0! Help needed
By showtime217 · Jan 28, 2013in AppRadio, AppRadio 2, AppRadio 3💬 10 posts👁️ 6,569 views
Posted Jan 28, 2013 · 00:38 UTC#1
This is a continued discussion from another thread on this site concerning rolling back from appradio 2.0 to 1.8.2.
http://avic411.com/index.php?/topic/34188-appradio-extensions-20-beta-full-iphone-control/page__st__645
If there is anyone that has accomplished this.. please let me know.
Odepaj has been great with assisting me with troubleshooting this reloading issue... Thanks again Odepaj!
Currently I have the orginal appradio 1.8.2.ipa and a cracked version of appradio 1.8.2.ipa (Odepaj provided via dropbox)
Both will upload into my itunes libary but when I try to install the app and sync my iphone 4S... It starts and then says "appradio failed to install".
That's about were I am with this......... sucks
My iphone 4S is jailbroke with 5.1.1.
Any help would greatly be appreciated
Posted Jan 28, 2013 · 00:56 UTC#2
Not that I think it would affect anything but what version of iTunes are you running?
And for the case of the cracked .ipa, do you have Appsync installed?
You might try rebooting the phone and your computer and try again.
I'm absolutely puzzled by this problem, because I had updated the app on my phone but then did exactly what you're trying to do so I could get back to v1.8.2
Posted Jan 28, 2013 · 02:18 UTC#3
I tried this process of adding the original and cracked 1.8.2 .ipa's to two different version of iTunes (current iTunes on pc and older iTunes on a laptop) both acted the same with the " appradio failed to install.
I'm not sure what appsync is but can download it to my iPhone if you think it will assist with uploading one of the version of 1.8.2 without the use of iTunes.
I did the same exact thing you did but I get the error. Totally sucks.. I work as a network engineer, so I'm not totally helpless but when it comes to apple/Mac I'm pretty weak....
Posted Jan 28, 2013 · 02:28 UTC#4
Go into Cydia and search for "AppSync for iOS 5.0+" and install that. If nothing comes up go into your Cydia sources and add "http://repo.hackyouriphone.org/" let that load up and then do the same search for AppSync again. After that is installed, the cracked .ipa file should work (it might make your original .ipa work also so test them both).
I only suggest hackyouriphone.org because it's the source I used for AppSync so I know that that deb works.
Edited Jan 28, 2013 by odepaj
Posted Jan 28, 2013 · 02:54 UTC#5
Ok so I loaded appsync. Now how should I reload the original and/or cracked versions.. From computer via iTunes or straight from the iPhone?
Posted Jan 28, 2013 · 03:20 UTC#6
Still from iTunes, just like normal
Posted Jan 28, 2013 · 18:39 UTC#7
Hello,
I thought I would confirm that I have managed to sucessfully downgrade to V1.8.2 by using the cracked .ipa and installing "AppSync for iOS 5+"
Many thanks
Edited Jan 28, 2013 by ErmyDermy
Posted Jan 28, 2013 · 21:57 UTC#8
It seems Pioneer have pulled the AppRadio app completely from iTunes, so to make things easier for people who need to downgrade or for anyone who just needs a working AppRadio app, I'm going to link the cracked .ipa in here.
https://dl.dropbox.c....8.2cracked.zip
Edit: For this to work on your iPhone, it needs to be jailbroken with AppSync installed.
Edited Jan 29, 2013 by odepaj
Posted Jan 29, 2013 · 00:22 UTC#9
Odepaj DUDE IT WORKED!!!! Thanks so much for taking the time to help me out! I really appreciate! And of course Mike thanks for creating such a cool app!!!!
Posted Jan 29, 2013 · 00:35 UTC#10
Awesome news! Glad to hear you're back on v1.8.2
