2010 Toyota Corolla
By darionovoa · Jan 31, 2013in Vehicle Specific Wiring💬 2 posts👁️ 3,217 views
Posted Jan 31, 2013 · 03:08 UTC#1
Anyone knows if there's a wire on the front (dashboard) that changes voltage on reverse?
I bought a wireless reverse cam and in order for the Pioneer radio to change automatically when on reverse it needs a wire connected to a reverse cable, I don't want to actually have to bring a wire from the back after buying a wireless cam.
Posted Feb 04, 2013 · 01:13 UTC#2
If you can't find the reverse to pick it wire in the dash you should be able to pick it up in the harness running down the passenger side. Lift the door sill plates, the harness will be at under the carpet. Look at the rear signal light and see if you can determine the wire color for the reverse lights.
This is where I picked up the signal in two of my cars.
