Reverse Wire / VSS location request - 2005 Ford Escape
By Jaymann20 · Feb 10, 2007in Vehicle Specific Wiring💬 2 posts👁️ 2,778 views
Posted Feb 10, 2007 · 05:08 UTC#1
Limited model w/ the Mach Stereo System if it matters.
TYIA,
Posted Feb 10, 2007 · 13:26 UTC#2
2005 Ford Escape
Speed Sense gray/black ABS or brake system control module
Notes: The ABS control module is on the rear driver side of the engine compartment. On the Hybrid models, the brake system control module is on the rear passenger side of the engine compartment.
On vehicles with the 6-disc in-dash CD changer, this wire is also found in the radio harness.
Reverse Light black/pink + driver kick or SJB, conn. C, pin 10
Notes: The SJB (Smart Junction Box) is the fuse/relay box on the passenger side of the center console.
Merry xmas
