Can not enter test mode on my x930bt, what do I do?
By s10blazer · Feb 06, 2013in Problems/Troubleshooting💬 16 posts👁️ 12,141 views
Posted Feb 06, 2013 · 23:41 UTC#1
In the process of trying to install new maps x930bt, deleted the wrong files during copy and pastes process of test mode. After I messed that up, the unit tries to install and update and fails, the message states ''program update failed'', restarts, and tries to repeat the install process again and again and it fails every time.
I can no longer enter test mode. What do I do? Any constructive help is greatly appreciated.
Posted Feb 07, 2013 · 06:49 UTC#2
The same problem.
Device reboot more & more.
Test mode not wirking.
I'm read service manual , may be file "ggs1098" needed?
Please help urgently!!!
Posted Feb 07, 2013 · 13:47 UTC#3
How are you trying to enter test mode? With sd card and testmode.key or by button presses?
Try pulling radio fuse or power (both yellow and red wires) for 10 minutes or so.
Posted Feb 07, 2013 · 16:57 UTC#4
I trying all of testmodes: 104bytes, 164bytes, 132bytes - the same resault.
Cards was 2Gb, 4Gb and 16Gb, formatetd with fat32 and fat - the same.
Device unplugged, and stay alone on the table :-)
So, I have full backup previosly state of device - NAND& NAND2, but how I can go to filemanager...
Pressing to buttons (Home+ then 3xback-forvard) - not working.
After upgrade all will be Ok, and testmodes was worked, but may be I delete same files from NAND...
Here little video of curren state http://sendfile.su/757813
May be you know another methods, such as formating flash, or have another files to lay on SD (for example as described in service manual: How to Start-up Test Mode
1. Download GGS1098 from the Service Site.
2. Decompress the file.
3. Copy the decompressed file to the SD card root.
4. Insert the SD card to the product and turn ACC on )?
Edited Feb 07, 2013 by aavica
Posted Feb 07, 2013 · 22:54 UTC#5
I am trying to enter using a sd card, how do I enter test mode another way? You mentioned something about buttons? what is that process?
Posted Feb 07, 2013 · 23:01 UTC#6
Try this:
keys combination to get into test mode manually by following: remove sd
card, turn on ignition, keep home button pressed and press previous,
next, previous, next and so on while keeping home button pressed until
the unit restarts, it should enter testmode.
In my case it does'nt working now :-(
Posted Feb 07, 2013 · 23:11 UTC#7
Try this:
I just tried it! I did not work for me at all! SO this is where I am,
Cant enter testmode both with an sd card or USB through Ipod cable
I also cant enter test mode through holding home and track forward and back sequence.
What other options do I have?
Thanks in advance
Posted Feb 07, 2013 · 23:12 UTC#8
Thanks in advance
Posted Feb 16, 2013 · 15:51 UTC#9
Thanks in advance
So, no any suggestions???
Posted Feb 16, 2013 · 17:38 UTC#10
if your unit does not boot into testmode with the following TESTMODE.KEY file placed on a FAT32 formatted sd card, then your unit is probably toast.
Posted Feb 17, 2013 · 11:03 UTC#11
So is a toast :-(
Is any firmware updates?
Posted Feb 18, 2013 · 16:43 UTC#12
So is a toast :-(
If your unit does not boot into testmode, then it will not boot into regular mode which is required to do upgrade.
So no.
Posted Feb 21, 2013 · 20:46 UTC#13
Just "successfully" installed Condi Hackmode 2.21 to X930BT. Rebooted > Radio came on > Startup Screen. That's it.
With or without SD Card - Same. Now I have a Radio. I can even change the stations by the Track buttons.
Any suggestions ????  Thanks for help .
Posted Feb 21, 2013 · 21:05 UTC#14
****UPDATE**** Put the TESTMODE.KEY (Supertestmode) on the card and can get into the Testmode. What Now ?
Posted Feb 22, 2013 · 17:38 UTC#15
UPDATE 2 - ************S O L V E D ************
Posted Mar 29, 2013 · 12:42 UTC#16
Hi all, recently faced such a problem also, on my F-930 ....
Watching topic subsided, do not have solutions to this problem???
