I recently purchased an N3 which will be going in my 07 vette.Does anyone make a wiring harness that makes this install easier?And does anyone know of a good installer in Orange County?
I'm a bit curious as to why you are putting an N3 in a Corvette. The C5's and C6's have double din openings to fit a Z1 or D1/2/3.
There are wiring harnesses available, but I don't know of them off hand. If you have a Bose system, the install will be a little tricky.
There is a full writeup on the D1 here: http://forums.corvetteforum.com/showthr ... ?t=1518095
Doesn't the C5 have a 1.5 din opening? You need to get a custom dash bezel to make it double din. Costs around 300 to make, or considerably cheaper if you make it yourself.
He said 2007
Then there's the obvious. The pic that jason posted is of the dash of a c6. Nice over sized double din.
I am referring to JasonH's comment about the C5 and C6 both having double dins.
